Questions à propo du dataloging, reprogrammation ...
MessagePosté le: 25/07/2011 16:23:20 Sujet du message: Questions à propo du dataloging, reprogrammation ... Répondre en citant
Sur ton lien le mec dit jute qu'il a acheté un P30 chippé et qu'il attends une carto sans iab de chez H-tune.
Observez cette photo d'un P9K: il n'y a pas d'emplacement libre pour mettre une mémoire additionnelle comme sur un ECU Obd1.
MessagePosté le: 25/07/2011 16:23:20 Sujet du message: Publicité
MessagePosté le: 25/07/2011 16:39:19 Sujet du message: Questions à propo du dataloging, reprogrammation ... Répondre en citant
a ok alors si je comprend bien on a beau vouloir faire l ecu p9k du mb6 ne sera jamais chippable
MessagePosté le: 18/04/2012 18:05:32 Sujet du message: Questions à propo du dataloging, reprogrammation ... Répondre en citant
Quelques infos sur le p9k:
Citation:
 Hello
This is a "how to" for OBD2a engines
Right so you have done and engine swap and you go to start the car and... oh no the immobilisers cut in!!!!
So your options..
-get a OBD1 ECU chip it
-go to honda and get them to pair your ecu and keys
OR
SWAP THE IMMOBILISER CHIPS!!!!
You need:
- Your origional OBD2a ECU
- ECU that runs your new OBD2a engine
- Solder Iron
- Philips Screw Driver
- Tools to take off ECU (10mm spanner)
Take the 2 immoblisers away from the car, get some clean to work on them.
Remove both the front and back plates from the ECU's, should be 4 screws on each side
Now you should have 2 ECU's that look like this:
Now locate the immobiliser chip, says IMMO above it
right, now comes the hard part
You need to carefully take hold of this chip whilst soldering the pins. Pull gently on the chip to ease it away from the board. I soldered it from the top but ive heard its better to do it from underneath.
PATIENCE!!! Dont rip it out you will pull the pins off the chip. If this happens dont worry just solder them back on.
Remember which is the chip that is pair to your keys, that will need to be re soldered into the new ECU.
Hold the chip over where it needs to be soldered and melt the solder whilst pushing the chip gently back in. Once its in DO NOT WIGGLE IT!!!
Now simply place the covers back on the front and back
Refit new ECU.
Now your car should start.
Ive done this twice now and both times it has worked.
I cant garentee it will work.
Tony
Source : http://www.civiclife.net/board/topic/73085-how-to-change-immobiliser-obd2a/
Donc un P9K ne peu pas être interchangeable entre 2 véhicules à cause de l’immobiliser ...
Et visiblement il est impossible de lire la map sur un p9k car elle est interne au microcontroleur (M66507-425) qui semble protégé...
MessagePosté le: 18/04/2012 20:11:44 Sujet du message: Questions à propo du dataloging, reprogrammation ... Répondre en citant
donc obliger si reprog de trouver un ecu p30 p28 ou p72
merci pour l info
MessagePosté le: 18/04/2012 20:40:49 Sujet du message: Questions à propo du dataloging, reprogrammation ... Répondre en citant
Sauf si on arrive à lire le microcontroleur dans ce cas il est possible de changer le MCU par un programmable si celui d'origine ne l'est pas
http://www.autoserve.8m.com/StepByStep_OBDII/Chip_Installation_OBD_II.html
Il m'en faut un pour tester, ça ne manque pas car c'est pas recherché vu qu'on ne peu pas en faire grand chose sauf remplacement standard, mais un ecu grillé c'est rare ...
MessagePosté le: 20/04/2012 16:13:27 Sujet du message: Questions à propo du dataloging, reprogrammation ... Répondre en citant
J'ai acheté un p9k sur ebay pour commencer les tests, le but étant de faire un bi cartographie (e858 / sp98) avec gain de perf sur les 2 et le tout à moindre cout. Voila pourquoi je m'obstine à garder le p9k plutôt que de passer sur un p72. Mais comme je l'ai dit c'est très loin d'être fait. pour le moment c'est la phase de test pour savoir si c'est réalisable il faut voir si il est possible de mettre une rom externe sur le MCU d'origine.
A savoir que en e85 avec une reprog bien foutue et un peu d'équipement à coté (échappement admission et peut être injecteur) je pense qu'on peu arriver a 190ch.
MessagePosté le: 20/04/2012 21:35:08 Sujet du message: Questions à propo du dataloging, reprogrammation ... Répondre en citant
Quelqu'un a une idée de l'interface ou du logiciel pour gérer les trames de l'ECU? Gratuit si possible... on me dit dans l'oreillette Hondata, Ectune, Crome... sont ils tous adaptés?
Tu comptes gérer comment tes réglages et ton gravage d'Eprom? Il va falloir s'équiper pas mal...
Perso je pense passer par ça pour lire et tester mes réglages => http://www.moates.net/ostrich-20-the-new-breed-p-169.html?cPath=69
Des collègues utilisent cela et c'est top mais je sais pas si je dois utiliser uniquement Hondata pour avoir les données reconnues et lisible...
Carto à venir de mon coté aussi Mr. Green
MessagePosté le: 20/04/2012 22:26:41 Sujet du message: Questions à propo du dataloging, reprogrammation ... Répondre en citant
pour le moment c'est la phase électronique chaque chose en sont temps.
tu compte faire la carto sur p9k via l'ostrich ?
et quel type de carto ?
MessagePosté le: 20/04/2012 22:42:58 Sujet du message: Questions à propo du dataloging, reprogrammation ... Répondre en citant
de quoi virer l’immobiliseur : http://www.doctronic.at/Mobilizier_Board_E.htm
 Il dit oui a tous les transpondeur, donc impossible de démarrer la voiture avec les câbles  Okay
MessagePosté le: 20/04/2012 23:00:28 Sujet du message: Questions à propo du dataloging, reprogrammation ... Répondre en citant
Merci pour l'info de l’immobiliser, mais c'est clairement pas ma priorité, je m'en passerais tout simplement... peut être à terme on verra
niavlysj
MessagePosté le: 03/07/2012 20:56:07 Sujet du message: Questions à propo du dataloging, reprogrammation ... Répondre en citant
RA.272 a écrit:
Histoire de vous faire rigoler un bon coup, voici les composants à rajouter sur un P28 ou P30 (Vti Eg6 par exemple) pour faire fonctionner les IAB:
Ca coute 5$ chez Xenocron:
http://www.xenocron.com/xenocron-add-iabs-parts-kit-p-131.html
je déterre.
quelqu'un aurait la référence de ces composants? histoire que file chez Selectronic et que je remap le C4 prévu pour circuit sur terre Wink
MessagePosté le: 07/09/2012 21:38:44 Sujet du message: Questions à propo du dataloging, reprogrammation ... Répondre en citant
je deterre aussi ^^
j'ai discuter avec Coubi du forum japancar, je vais voir avant la fin de l'année pour me faire une carto et apparament avec gestion de l'iab. donc je vous tiens au jus si ça y va sans soucis. si cela fonctionne vous n'aurez plus qu'a vous tourner vers lui pour une carto sans changer de collecteur d'admi Wink
MessagePosté le: 08/09/2012 10:56:25 Sujet du message: Questions à propo du dataloging, reprogrammation ... Répondre en citant
Pense aussi à la bimap ethanol !
MessagePosté le: 08/09/2012 12:06:09 Sujet du message: Questions à propo du dataloging, reprogrammation ... Répondre en citant
voir quadrumap car il reste toujours au moin 10 l de sp dans le reservoir pour mettre le plein e85
garder carto stock pour le sp
       carto a 50 50
       carto a 80 20
       carto a 100 pourcent e85
je pense que c est vraiment le must
dit moi si je me trompe Mr. Green
MessagePosté le: 08/09/2012 18:02:20 Sujet du message: Questions à propo du dataloging, reprogrammation ... Répondre en citant
oui mais pour ces quelques variations le calculateur corrige Wink
MessagePosté le: 23/01/2018 05:03:52 Sujet du message: Questions à propo du dataloging, reprogrammation ...
Page 3 sur 5
